Problems sending mail
Print Print
There are a few common reasons why Gmail users may have trouble sending mail with Gmail's IMAP or POP feature. There are A Few Common Reasons Why Gmail users May Have trouble sending mail with Gmail's POP or IMAP feature. If you can't send mail, here's a troubleshooting checklist: If you can not send mail, here's a troubleshooting checklist:
Are you able to log in to the Gmail web interface? Are you Able to log in to the Gmail web interface?
Visit
http://mail.google.com to log in to Gmail. Visit
http://mail.google.com to log in to Gmail. If you see a CAPTCHA (a security image with distorted letters), you'll need to log in before you can enable IMAP access. If you see a CAPTCHA (a security image with distorted letters) to log in'll Need Before You Can enable IMAP access. If you're locked out of Gmail, please wait one hour and log in to Gmail again. If you're locked out of Gmail, please wait one hour and log in to Gmail again.
Have you enabled POP or IMAP in Gmail? Have you enabled POP or IMAP in Gmail?
Sign in to the Gmail web interface .Open the 'Forwarding and POP/IMAP' tab on your 'Settings' page, and configure IMAP or POP. Sign in to the Gmail web interface . Open the "Forwarding and POP / IMAP 'tab on your' Settings' page, and configure IMAP or POP. After enabling this in Gmail, make sure you click 'Save Changes' so Gmail can communicate with your mail client. After Enabling this in Gmail, make sure you click 'Save Changes' so Gmail dog Communicate with your mail client.
Did you enable SSL for the SMTP server? Did you enable SSL for the SMTP server?
Make sure SSL is active for SMTP in your mail client. Make sure SSL is active for SMTP in your mail client. For more information, please review the configuration instructions for your specific client. For more information, please review the Configuration Instructions for your specific client.
Did you set 'allow authentication' for the SMTP server? Did you set 'allow authentication' for the SMTP server?
Check that 'allow authentication' is active for the SMTP server in your mail client. Check That 'allow authentication' is active for the SMTP server in your mail client.
Did you enter the correct username and password? Did you enter the correct username and password?
Verify that your username is spelled correctly, and that you've entered '@gmail.com.' Verify your username is Spelled That CORRECTLY, And That you've enter '@ gmail.com. " Google Apps customers should enter their entire email address including the domain name. Customers should enter Google Apps email address Their Entire Including the domain name. Also, you should re-enter your password just to be sure it's correct. Also, you should re-enter your password just to be sure it's correct.
Are you trying to send attachments? Are you trying to send attachments?
As a security measure to prevent potential viruses, Gmail does not allow you to send or receive executable files that could contain damaging executable code. As a security measure to Prevent Potential viruses, Gmail does not allowed you to send executable files or Receive Damaging That Could Contain executable code. Also note that with Gmail, you can send and receive messages up to 25 megabytes (MB) in size. Also note That with Gmail, You Can Send and Receive messages up to 25 megabytes (MB) in size.
Still can't send mail? Still can not send mail?
If you tried configuring your SMTP server on port 465 (with SSL) and port 587 (with TLS), but are still having trouble sending mail, try configuring your SMTP to use port 25 (with SSL). If you Tried configuring your SMTP server on port 465 (with SSL) and port 587 (with TLS), But are Still HAVING trouble sending mail, try configuring your SMTP to use port 25 (with SSL).
Apple Mail users: At times, Mail may misinterpret your SMTP server settings. Apple Mail users: At times, Mail Misinterpret May your SMTP server settings. If you currently have 'smtp.gmail.com:
[email protected]' in the 'Outgoing Mail Server:' field of your settings, please try changing the field to 'smtp.gmail.com' and saving your settings. Currently if you have 'smtp.gmail.com:
[email protected]' in the 'Outgoing Mail Server:' field of your settings, please try Changing the field to 'smtp.gmail.com' and saving your settings.
Seeing duplicate Sent messages? Seeing Sent duplicate messages?
To understand settings that affect deleting and storing messages and drafts, please visit our recommended client settings . To Understand That Affect settings and STORING deleting messages and drafts, please Visit our recommended client settings .
Can you connect to the SMTP server? Can you connect to the SMTP server?
To better diagnose the problem, you'll need to run a telnet test, which will check that your computer can contact our SMTP servers. To Better Diagnose the problem, you'll Need to run a telnet test, Which Will check your computer That dog contact Our SMTP servers.
If you're running Windows Vista, you'll first need to enable the Telnet feature: If you're running Windows Vista, you'll Need to first enable the Telnet feature:
Click the Start button, then Control Panel , and Programs . Click the Start button, Then Control Panel, and Programs.
Click Turn Windows Features On or Off . Click Turn Windows Features On or Off.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation. If you are an administrator Prompt for password or confirmation, type the password or confirmation Provide.
In the Windows Features box, check the box labeled Telnet Client , and click OK . In the Windows Features box, check the box labeled Telnet Client, and click OK. (It may take a few minutes for the installation to complete.) (It May take a FEW minutes for the installation to complete.)
To run the telnet test on a Windows computer: To run the telnet test on a Windows computer:
Open the Start menu, and select Run . Open the Start menu, and select Run.
Enter command in the Open: field, and click OK . Enter command in the Open: field, and click OK.
Enter 'telnet smtp.gmail.com 465,' and hit Enter , or if you're using Outlook 2007, enter 'telnet smtp.gmail.com 587' instead. Enter 'telnet smtp.gmail.com 465,' and hit Enter, or if you're using Outlook 2007, enter 'telnet smtp.gmail.com 587' instead. (Does the information in the prompt window clear? If not, please note the message that appears.) (Does the information in the prompt window clear? If not, please note the message That Appears.)
Close the prompt window. Close the prompt window.
To run the Telnet test on a Mac: To run the Telnet test on a Mac:
Click the Macintosh Hard Drive icon, and open the Applications folder. Click the Macintosh Hard Drive icon, and open the Applications folder.
Open Utilities , and select Terminal . Open Utilities, and select Terminal.
Depending on what port you're using to send, type 'telnet smtp.gmail.com 25' or 'telnet smtp.gmail.com 587' in the prompt window and press Enter . Depending on What port you're using to send, type 'telnet smtp.gmail.com 25' or 'telnet smtp.gmail.com 587' in the prompt window and press Enter.
If you receive an error message after performing step 3, your network administrator or security software has blocked access to our servers. If You receive an error message After performing step 3, your network administrator or security software has blocked access to Our servers. We recommend contacting your local network administrator or Internet Service Provider (ISP) for more information. We recommend Contacting your local network administrator or Internet Service Provider (ISP) for more information
