please help a noob
jvk
jhb
hi
basically i want to get two packages one uncapped (mweb) and one capped (prob cybersmart) can anyone
tell me how to change between accounts or post a link to a thread showing the full steps ? (tried searching
the forum but cant get exact details)
basically i just want to know how i can switch between the isp's when the uncapped becomes to slow.
thanks
Easiest way is to switch your router into bridge mode and configure the two accounts on your PC.
Change the log in detail of your router?
Open firefox or similar.
Type the address of your router in, usually 192.168.0.1 (Look on the bottom of your router, usually has the default information)
Then login to your router.
Then look for basic settings (login details and password)
Change them to switch accounts.
You'll need to reconnect to the internet so reboot router.
EDIT:
Drake2007 way is easier, and less hassle, but I don't like the idea of my pc being directly on the internet.
