Hi all. I am quite knowledgable about PC's and technology (a lot more than most
) but am clueless about wireless networks unfortunately. The situation is this: we have a network at home between two PC's. We will be adding a third in a couple of weeks. The PC's are always on (at least the primary one with the internet connection, the others 95% of the time).
Currently the two are connected directly with an ethernet cable between their network card. The internet connection is iBurst connected to the primary PC via USB (I know this is the ADSL forum but the question is related only to the WLAN, not the internet connect I believe, right?) and Windows XP using its internet connection sharing works 100%. The third PC will be in another room about 25m away.
Instead of installing a hub and ethernet cables across the house I want to setup a WLAN. What would I need, other than 3 wireless network cards (one for each PC)? Also, could I use the ICS (internet connection sharing) of XP as is without having to change any of the settings?
Thanks in advance,
Thanks in advance,
