B bradsport Member Joined Feb 26, 2009 Messages 21 Reaction score 0 Aug 23, 2011 #1 hi i have a ideos s7 slim and for some reason it cannot connect to the internet on cellc please advise
OMB Mountain Man Joined May 6, 2010 Messages 39,597 Reaction score 94 Location right here Aug 23, 2011 #2 not much info to work with, what have you tried so far, have you set your APN etc?
B bradsport Member Joined Feb 26, 2009 Messages 21 Reaction score 0 Aug 23, 2011 #3 i put internet as the apn and port 8080 that is what i got from an sms from cell c
O oldhat Executive Member Joined Jun 27, 2007 Messages 6,037 Reaction score 1,054 Location Gqeberha Aug 25, 2011 #4 Have not tried CellC, will test & post results later. Vodacom works automagically once you enable data access over mobile network in settings... Sent from my IDEOS S7 Slim using MyBroadband Android App
O Ockie Resident Lead Bender Joined Feb 16, 2008 Messages 55,170 Reaction score 7,438 Location Henceforth AKA OckieMoto :-) Aug 25, 2011 #5 The S7 does not support UMTS 900mhz. It should still connect though...but unless Cell C have a 2100mhz tower in your area that you can connect to you wont be getting 3G on it..no way no how!
O oldhat Executive Member Joined Jun 27, 2007 Messages 6,037 Reaction score 1,054 Location Gqeberha Aug 26, 2011 #6 Tried CellC sim - does not work :-( Also getting conflicting info regarding S7's 900MHz support - will investigate further...
