Ok, so I bought a 750GB and put it in an external enclosure...
I plug it in the USB, I get devices were properly installed but I still cant see anything in my computer?
If I were you, I would first plug it into the computer, initialize the disk, partition and format, copy your data, THEN put it into the external enclosure.
To do it all through the USB is going to take you a couple of days.
because magically it must have a partition table and filesystem, yeah.
it is a blank hdd, so go to computer maangement, disk administrater and initialise the drive.
or, in old-skool speak, fdisk+format.
Correct. or:
go to admin tools > computer management > disk administrater and format the drive.
Tried that, but my computer never picked it up
1) Does it show up in the BIOS? Have you set the BIOS to see it?
2) You have to initialize it in Windows....
go to Administrative Tools, Computer Management, Disk Management...
Scroll down until you see the new disk, right click on it and choose "Initialize"
you might have to reboot.
http://technet2.microsoft.com/windo...069a-4a5d-8cad-6be0fdec01091033.mspx?mfr=true
http://news.softpedia.com/news/Disk-management-under-Windows-XP-31331.shtml
+1 --- what Garyvdh said....
Your SATA ports must be enabled in your BIOS to begin with - usually DEL or F2 or F10 to get into your BIOS to change this setting - which motherboard/model do you have?
No its not my first SATA drive...
Well, I went to Incredible and they formatted it, and now its working... Oh well![]()
Extrremely odd
But hey![]()
Did you buy it at IC? How much was it??
No, I bought my 750GB from Take2
Formatted at IC for R50![]()
