Please help Hunter Markros for BM?
Boomrooker
I am looking for some hunter markros for Bm i can copy and paste into my macro thing cause i suck at making costum makro never works just the text stuff do.
Thx in advance
It's not really work macro'ing a shot rotation till you get Steady Shot and Kill Command.
As a BM Hunter I use a few macro's for silly things like my Hunters Mark.
#showtooltip Hunters Mark
/petattack
/cast Hunters Mark
Just sends my pet in when I mark my target to make my pet control a little easier.
Once I get steady I'll do a proper shot Rotation but until then I just weave Arcane and Serpent in between my normal shots and a Swing Timer (Quartz) to track my Autoshot timing.
/petattack
/cast Hunters Mark
I cant find Quartz adon anywere?
Can i just copy paste this in my macro?
/petattack
/cast Hunters Mark
/petattack
/cast Hunters Mark
Try www.curse-gaming.com for WoW addons
And yes, ingame type "/m" to open the macro menu, create new, give it a name and copy and paste that into it exactly as you see it
First of you talk about Markros, Macro and Makro. What on earth are you aiming at :confused:
There is a huge list of Macros for hunters and all other classes at wowwiki, including the macros that we have discussed on the forums here. Just search for them, I know you have posted in some of those discussions, al be it totaly off topic :p
Yeah you should be able to get Quartz off the Curse site.
Copy/Paste that macro will work too.
Here is your basic most important shot macro's used by all BM hunters. 3:2 + 1:1 shot rotations.
In a nuthsell... 3:2 is max damage/ dps macro at the expensive of being very heavy mana intensive... 1:1 is good dps at a more conservative mana usuage.
3:2 rotation makes max dps @ a weapon shot speed of 2.07 if memory serves me right.
3:2 rotation :
#showtooltip
/console Sound_EnableSFX 0
/cast !Auto shot
/cast Steady Shot
/cast [target=pettarget, exists] Kill Command
/script UIErrorsFrame:Clear()
/console Sound_EnableSFX 1
The 1:1 rotation :
#showtooltip Steady Shot
/castsequence reset=3 Steady Shot, !Auto Shot
/castrandom [target=pettarget, exists] Kill Command
Slightly modified variances of the macro's :
3:2
/cast !Auto Shot
/cast Steady Shot
/script UIErrorsFrame:Clear();
1:1
/castsequence reset=3 !Auto Shot, Steady Shot
Survival hunter 1:1.5 rotation
/cast !Auto Shot
/cast Steady Shot
Note the survival macro does not have kill command in it for two simple reasons... usually their pet does weak damage + kill
command mana usage doesnt justify the damage return.
Now before you start copying and pasting macro's from any site you get on the net... its actually very easy to spot who the "huntards" are, and who the people are that actually read patch notes and keep themselves up to date with macro's.
Huntard identification 101 :
1 - Any macro without ! in front of the Auto Shot ... close the browser as fast as you can and never ever ever read / believe anything that guy tells you. Clearly that person does NOT read patch notes, and has no idea what has changed numerous patch releases waaaay back when the syntax was modified in the macro structure by Blizz devs.
2 - Any macro with a modified reset=(insert weapon speed) line in it... refer to point one and close browser as fast as possible. That is NOT the function of the reset value.
Bleh tired of typing now... gonna slack and read WoW forums... since its Friday anyway.
Hi guys, im looking for a hunter makro that puts hunters mark on target and sends pet after him. I know its a simple one, any help? thanks
/cast Hunters Mark
/cast Petattack
Should do what you want... Just check the right spelling ;)
I use a sligtly modified version of this. I have mapped the " ` " key to cast hunters mark, and send the pet in. Hitting the key stop the pet attacking and run back to you (works great if you have to keep your pet alive from boss aoe etc...)
This macro a long with LOTS of other hunter macros are discribed in wowwikki under hunter macro's. To repeat half of them here would be insane.
Other nice hunter macro there is the all in one pet care. It feeds the pet when not in combat and heals it when in combat...
All in one stings macro, ctl-click for tranq shot, alt-click for scorpid, normal click for serpent sting. Similar macro for traps.
Or the melee fight macro, to winglclip, raptor, mongoose etc with spamming one button.
