Please help me configure a home router
upup
currently offline
My setup is in the pic. When I connect the computer via the tenda, there is no internet, but I don't no how to set it up.
Currently the computer comes strait from the marconi. Now I want it via the Tenda, 1; to get printer going, and wifi at computer area.
I only set the password on wifi name on the tenda.
Make sure the tenda router is not the DHCP server in this case.. the tenda should be relaying dhcp requests..
DHCP was enable, I disable it ,connect wan port on marconi and the other port to computer, no internet . What is wrong please
Why wan port ? Just use it as a switch and set mode as access point and not router
Thank you, working, but seems wifi is not working from tenda as well as printer not printing, but I can ping it.
What do you suggest.
The marconi is 10.0.0.2 and the tenda, 192.168.0.1 if that matters.
your ip setup is incorrect, configure tenda with manual ip, 10.0.0.3 and its gateway is the marconi and same subnet mask. It needs to relay DCHP requests.
