TheSparrow
- Feb 2, 2021
Hello guys
I just moved into an appartment and there was already a fiber line with an ONT. I phoned supersonic for a fiber installation and told them about the ONT so they said they only needed the B number to take over the line. A B number is assuming that the line was installed by Openserve right?
There is a serial number stuck on the ONT, but it's not one I recognise. Could any of you tell me if you know what fiber provider its from?
ONT model: Nokia 2019 G240G-C
Serial number sticker: ALCLFA6A9673
Thanks!
UPDATE:
The ISP used to be Afrihost, but even with the address and the ONT serial number they can't give me the B number without the account details. The afrihost technician told me if Supersonic gives me the PPoE details and I configure my router then Supersonic will be able to get the B number, the supersonic technician said they can't do that for some reason. I'll just have to wait.
The PON light on the ONT is green and the Auth light is green, so there's an successful connection to the OpenServe network. I'm pretty sure I can get everything working myself if they just give me the right info, right?
Thanks!
UPDATE:
