Please help me set up my WCF for .Net.
foozball3000
Kyalami
For starters, I should state that I'm fairly clueless on this topic.
I have a website that references a web service, using basicHttpBinding.
If I have methods that return XML as string, everything works fine, but as soon as I try to add my own custom object to use for data transfer, nothing works. I have checked the code against the MSDN library, and it seems correct.
Is there something I'm missing here?
Code:
    [ServiceContract]
    public interface IUploadService
        [OperationContract]
        string ReturnNewOrder(string OrderKey);
        [OperationContract]
        Document GetAnOrder();
        [DataContract]
        public class Document
            private string _doccode;
            [DataMember]
            public string Doccode
                get { return _doccode; }
                set { _doccode = value; }
            private List<DocumentLine> _lines;
            [DataMember]
            public List<DocumentLine> Lines
                get { return _lines; }
                set { _lines = value; }
        [DataContract]
        public class DocumentLine
            private string _itemcode;
            [DataMember]
            public string ItemCode
                get { return _itemcode; }
                set { _itemcode = value; }
            private int _quantity;
            [DataMember]
            public int Quantity
                get { return _quantity; }
                set { _quantity = value; }
The error only appears when I compile the website's code:
Code:
Error	14	Reference.svcmap: Failed to generate code for the service reference 'UploadService'.  Cannot import wsdl:portType  Detail: An exception was thrown while running a WSDL import extension: System.ServiceModel.Description.DataContractSerializerMessageContractImporter  Error: Could not load file or assembly 'xxx.dll, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.  XPath to Error Source: //wsdl:definitions[@targetNamespace='http://tempuri.org/']/wsdl:portType[@name='IUploadService']  Cannot import wsdl:binding  Detail: There was an error importing a wsdl:portType that the wsdl:binding is dependent on.  XPath to wsdl:portType: //wsdl:definitions[@targetNamespace='http://tempuri.org/']/wsdl:portType[@name='IUploadService']  XPath to Error Source: //wsdl:definitions[@targetNamespace='http://tempuri.org/']/wsdl:binding[@name='basicHttpBinding']  Cannot import wsdl:port  Detail: There was an error importing a wsdl:binding that the wsdl:port is dependent on.  XPath to wsdl:binding: //wsdl:definitions[@targetNamespace='http://tempuri.org/']/wsdl:binding[@name='basicHttpBinding']  XPath to Error Source: //wsdl:definitions[@targetNamespace='http://tempuri.org/']/wsdl:service[@name='UploadService']/wsdl:port[@name='basicHttpBinding']	App_WebReferences/UploadService/
When you add the Service Reference, open the Advanced dialog and uncheck the 'Re-use types in referenced assemblies' checkbox.
