BarnettE
Lately I have been getting many web sites timing out or loading partially. I phoned MWeb and Telkom and both said that they see nothing wrong and insisted the problem must be with the other company. Telkom did however "reset the line" and after that I thought it was working fine. When I ping the nearest device on the other side of the ADSl line, the ping times were consistent and very close to 10ms:
But that did not last very long. This is what I am getting for the last few days:
Any ideas what the problem can be? What other tests can I do?
Code:
C:\>tracert www.mweb.co.za
Tracing route to www.mweb.co.za [196.2.63.110]
over a maximum of 30 hops:
1 1 ms 1 ms <1 ms 10.0.0.2
[U]2 8 ms 9 ms 8 ms 41-133-130-1.dsl.mweb.co.za [41.133.130.1][/U] <<<<<<<<<<<<<<<<<<<<<<<
3 10 ms 10 ms 10 ms te1-1-0.502.cpt-ipc-1.mweb.co.za [196.28.178.166]
4 10 ms 10 ms 10 ms 197-84-2-2.cpt.mweb.co.za [197.84.2.2]
5 10 ms 9 ms 10 ms ^C
C:\>ping 41.133.130.1 -t
Pinging 41.133.130.1 with 32 bytes of data:
Reply from 41.133.130.1: bytes=32 time=10ms TTL=253
Reply from 41.133.130.1: bytes=32 time=9ms TTL=253
Reply from 41.133.130.1: bytes=32 time=11ms TTL=253
Code:
Reply from 41.133.130.1: bytes=32 time=38ms TTL=253
Reply from 41.133.130.1: bytes=32 time=53ms TTL=253
Reply from 41.133.130.1: bytes=32 time=35ms TTL=253
Reply from 41.133.130.1: bytes=32 time=44ms TTL=253
Reply from 41.133.130.1: bytes=32 time=34ms TTL=253
Reply from 41.133.130.1: bytes=32 time=21ms TTL=253
Reply from 41.133.130.1: bytes=32 time=43ms TTL=253
Reply from 41.133.130.1: bytes=32 time=61ms TTL=253
Reply from 41.133.130.1: bytes=32 time=50ms TTL=253
Reply from 41.133.130.1: bytes=32 time=12ms TTL=253
Reply from 41.133.130.1: bytes=32 time=28ms TTL=253
Reply from 41.133.130.1: bytes=32 time=41ms TTL=253
Reply from 41.133.130.1: bytes=32 time=13ms TTL=253
Reply from 41.133.130.1: bytes=32 time=22ms TTL=253
Reply from 41.133.130.1: bytes=32 time=51ms TTL=253
Reply from 41.133.130.1: bytes=32 time=57ms TTL=253
Reply from 41.133.130.1: bytes=32 time=39ms TTL=253
Reply from 41.133.130.1: bytes=32 time=54ms TTL=253
Reply from 41.133.130.1: bytes=32 time=20ms TTL=253
