PLEASE HELP! PC TROUBLES
nauseous_monkey
/\/ÂŻÂŻÂŻÂŻÂŻ\/\
Hey guys.
My PC keeps rebooting itself. When it starts back up I get a 'The System has recovered from a serious error' message in Windows XP.
Error Signature:
BCCode : 1000008e BCP1 : C0000005 BCP2 : BFB0FED5 BCP3 : BA35E870
BCP4 : 00000000 OSVer : 5_1_2600 SP : 2_0 Product : 256_1
Files included in error report:
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\WERa7bf.dir00\Mini072308-03.dmp
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\WERa7bf.dir00\sysdata.xml
What am I dealing with here (hardware issues or a virus?) and how do I solve it?
this happened to me 2 or 3 times a few weeks ago ..... had no idea what the problem was :o
I've never seen that error before but:
Got to COntrol Panel->SYstem->advanced->startup&recovery and switch off the option that says reboot on error. That way you can get a better look at the error.
this could be anything really
i saw that type of error on a symantec av update ones
but the first thing to do is try and update the graphics drivers
and maybe install xp sp3
could be some prog in your startup ( msconfig )
I had the same issue with my machine awhile back - Turned out to be a bum motherboard unfortunately....70% of the time random rebooting is caused by a hardware fault and generally it is the MB that is dead.
If it is not the video drivers... get hold of a copy of Ultimate Boot CD or Hiren's Boot CD and run some RAM tests.
