Please help with Uncaught ReferenceError: TrustLogo is not defined
D3athD00r
Fourways
Hi Guys,
I'm currently stumped with getting my SSL logo onto my site. The error I get in chrome's developer tools is "Uncaught ReferenceError: TrustLogo is not defined"
When I look at the script supplied by the comodo website I don't know what could be the issue.
here is the offending code:
Code:
<script language="JavaScript" type="text/javascript">
TrustLogo("https://*.co.za/wp-content/uploads/2015/11/comodo_secure_100x85_transp-compressor.png", "CL1", "none");
</script>
<a  href="https://ssl.comodo.com" id="comodoTL">SSL Certificate</a>
Please help steer me in the right direction
Thanks in advance
Hi D3athD00r
You are getting this error because the function you are tying to call does not exist in your case it's "TrustLogo".
Please add this part before your script tag <script language="JavaScript" src="https://secure.comodo.net/trustlogo/javascript/trustlogo.js" type="text/javascript">
</script>
it should look like this
</script>
</script>
Hope this helps
Kind Regards
Hi D3athD00r
</script>
</script>
</script>
Hope this helps
Kind Regards
Thank-you very much BladedGhost. That code has worked perfectly.
I wonder why their wizard doesn't have this
