Please help!!!
essop1@gp
Pretoria
Hi guys
i'm new at ubuntu, i've just installed 10.04 on my dell inspiron 1501, but i've been having problems with the wireless adapter, its not working, i've been through forum after forum and finally managed to download drivers and ndiswrapper, ran everything as they said but now i'm stuck.
sudo modprobe ndiswrapper - when i run that, i get a /etc/modprobe.d/blacklist error
what to do from here on to get my wireless working?
Please help
Well all the forums that i;ve been through state that the drivers included with ubuntu don't work, which is true, i can't even switch my wifi on and off, the wifi light just stays green and thats it. And with ndiswrapper, the first time i tried to execute that function, i got a message stating that ndiswrapper is not installed followed by agt-get install ndiswrapper-common
But anyway i've been through all the works, but i am now stuck on the last command sudo modprobe ndiswrapper
You can edit the blacklist file, though my concern would be why it was blacklisted.
Try the man system if there's any info there e.g.
man modprobe
man sometimes also works on the configuration file e.g.
man blacklist
There was an initial blacklist instruction for bcm43xx, apparently that prevented the current ubuntu driver from loading after reboot inorder to get the new one working.
i will try that
ndiswrapper is blacklisted to prevent it from being loaded in favor of native kernel drivers. You can just remove it from the blacklist.
sudo nano /etc/modprobe.d/blacklist
remove ndiswrapper from the list, ctrl+o to safe changes.
Give us the output of:
sudo lspci
00:00.0 Host bridge: ATI Technologies Inc RS480 Host Bridge (rev 10)
00:01.0 PCI bridge: ATI Technologies Inc RS480 PCI Bridge
00:05.0 PCI bridge: ATI Technologies Inc RS480 PCI Bridge
00:06.0 PCI bridge: ATI Technologies Inc RS480 PCI Bridge
00:12.0 SATA controller: ATI Technologies Inc SB600 Non-Raid-5 SATA
00:13.0 USB Controller: ATI Technologies Inc SB600 USB (OHCI0)
00:13.1 USB Controller: ATI Technologies Inc SB600 USB (OHCI1)
00:13.2 USB Controller: ATI Technologies Inc SB600 USB (OHCI2)
00:13.3 USB Controller: ATI Technologies Inc SB600 USB (OHCI3)
00:13.4 USB Controller: ATI Technologies Inc SB600 USB (OHCI4)
00:13.5 USB Controller: ATI Technologies Inc SB600 USB Controller (EHCI)
00:14.0 SMBus: ATI Technologies Inc SBx00 SMBus Controller (rev 13)
00:14.1 IDE interface: ATI Technologies Inc SB600 IDE
00:14.2 Audio device: ATI Technologies Inc SBx00 Azalia (Intel HDA)
00:14.3 ISA bridge: ATI Technologies Inc SB600 PCI to LPC Bridge
00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron]
HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:05.0 VGA compatible controller: ATI Technologies Inc RS482 [Radeon Xpress 200M]
05:00.0 Network controller: Broadcom Corporation BCM4311 802.11b/g WLAN (rev 01)
08:00.0 Ethernet controller: Broadcom Corporation BCM4401-B0 100Base-TX (rev 02)
08:01.0 SD Host controller: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 19)
08:01.1 System peripheral: Ricoh Co Ltd R5C843 MMC Host Controller (rev 01)
