please help!
wolverinex
Hi
Anyone know were i can still purchase a G31 mobo ?
matrix unfortunately no longer stocks it.
also please let me know if any of you guys are willing to sell me one that you maybe have lying around and not using.
i'm in the jhb area.
my mobo died and can afford to upgrade just yet so i decided to maybe try and get a replacement mobo.
thanks guys
Why does it have to be a G31? Why can't it be any other socket 775 MB?
Anyway Prophecy has some Foxconn & Gigabyte G41 boards in stock, MSI & ASRock as well but I would stick to the first two brands I mentioned.
http://www.prophecy.co.za/bintelb-socket-lga775-c-82_94_100.html
EDIT: Oops, See some G42 boards use DDR3 but not all and there is a Asrock G31 board.
Pretty much impossible to find. Try second-hand.
Even G41 with DDR2 are impossible to find.
wooooooooohoooooooo
thanks guys !
managed to find one second hand.
thanks for the link ponder
