please help
brat69
kzn
can someone please tell me the quickest way to finsh nfs most wanted.:confused:
Get your Bounty as high as u can ... that will make the next challenges easier as u dont have to chase away from the cops again with the next member of the Blacklist. Which member u at ?
i am only on #12! i dnt play often but i really want to finish the game. is there any cheats to get extra money?
thanx Pitbull
playing this on the PSP...it's not too difficult on "normal" setting to play. I'm stuck on #7. Think you just need to upgrade so race a few times on the same track to earn more money. Unless the PSP version is different fromt he PC???
As soon as you start using cheats, youll find that the game loses it's appeal. My tip is stick with one car and upgrade it to the max. You save a lot of money and that car will pwn. Also to get up your bounty, there is a bus stop somewhere near the middle of the map. Once you are on heat 3 or so and got lots of cops chasing you, drive inside and up the ramp. Just sit there and watch the chaos :D
