Please stop building under high-voltage power lines - Eskom
Jan
Who's the Boss?
Staff member
The Rabbit Hole
Eskom begs people to stop building under high-voltage power lines
Eskom has appealed to South African residents to stop erecting houses and other buildings under its high-voltage power lines.
The power utility said it had observed an increase in such structures built within servitudes — the land below and adjacent to power lines.
Well the police are meant to be doing their job when eskom or someone reports someone doing so. But hell them to die if they build under it
Why should they even ask.
Its insane that people are even able to do this.
Exactly.
And back in civilisation when Eskom actually needs to construct a power line that even comes remotely close to a civilised area they need people to remove themselves because something as simple as a playground could have massive residual electrical charges where touching a raw bolt could electrocute you.
There is a big chunk of houses in Athlone right under a 66kV set of cables. There are 4 sets of 2 cables and now and then you can see them glowing in the dark
Been like this since the 1960's.
A what now?
As in an unpainted metal bolt, used to put things together.
We have a Spar in our area that's built underneath some massive pylon lines.
Then a year or so ago one of the pylon cables close to it in my area broke... set the whole veld on fire and rained down ash for a few minutes, luckily it dropped on a pathway that wasn't being used at the time... probably the biggest explosion I've ever seen.
I haven't been back to that Spar yet.
Would Eksedom not have to find them alternative accommodation? Anyway, I am surprised they haven't swing a line over the cables to either get free power or steal them; maybe they have.
