Same. It means we are missing some sort of valve somewhere near the geyser which is meant to prevent this kind of thing. Shortcuts taken by the plumber / installer. I live with it. Geyser is 30 years old - I'm not messing with it till I have to.
Are you talking about the Vacuum Breaker's ?
Could be missing a vacuum breaker on the supply side of the geyser I guess.
Basically, water is running backward out of the geyser into the cold supply line, and from there out the taps.
http://www.housecheck.co.za/hot-water-geysers/
I think you're right. I seem to recall I only have a vacuum breaker on the geyser outlet, hence my same problem as op.
Be aware then that your cold taps will empty your geyser, and switch off your element if you have a water outage, to prevent it burning out...![]()
