POE Switch and Pc's
greggpb
I was wondering if you use a poe switch
Such ar the planet FNSW-2400PS and plugged Pc's into it would it fry them like the old POE injectors would ?
Kind regards
Gregg
No (pdf, download and scroll through to page 15 for PSE/PD 'handshake' (for want of a better word). Also, I *have* stuff connected to my PoE switch, the result has been utterly underwhelming. :) Also: wiki
Careful if you use injectors. Some cheaper ones are not 802.3af/at compliant so they just push power no matter what the end device says.
