Polo wheel nut lock.
anonymous2010
Hi,
Looking for the adapter that fits into the wheel lock nut of a Polo.
Does anyone know where I can get one.Have tried agents - don't sell them anymore.
Thanks.
The key? If that's what you're looking for, it's specific to your lock nut set...
You may be able to buy one from VW, if it's been discontinued (likely), they'll do their best to sell you a new set for +/- R800.
I convinced them that they lost mine, and they should supply a new set.
After about a week of "we'll investigate and get back to you", a key for my set magically appeared somewhere in their warehouse :)
Mag wheel shops can usually break the nut and install a new set for you... not sure what they charge tho.
TW&T will not be very expensive, and they will remove the old ones and supply you with a new set.
