Pool cleaner issue
IamNoone
DRC
My pool cleaner keeps missing this spot.
Anyone have a solution for this?
I have the same problem - but unfortunately no solution.
I just brush the dirty spot and hope it lands where the Creepy sucks.
Yup, as Sinbad just said, and if that doesnt work you get a rotating thingy you add between 2 hoses so that hoses dont get tangled or knotted. Foget what they're called now
Had the same **** with my pool. Tried lots of things. Eventually gave up and just bought an MX8 Pool Cleaner from Game on special. Problem solved.
