Hi all
I have a 5 x 2.5m pool that I'm looking to heat up.
I'm currently looking at a 5kw heat pump. Would this be sufficient?
If so, I'm looking for info on how long would it take to heat up. I'll probably only use it once or twice a month so not looking to run it all the time. What would be the electricity usage in units per hour as well?
Another question, which smart switch can I use on my DB so I can switch on and off via WiFi.
