Sideshow Bob
So, I cleaned both the baskets, one at pool side and one at the pump side and baracuda making gargling noises. There is heat pump as well but considering temp is 29 degree right now, that seems fine.
I ran backwash for 20 seconds and then rinse for 10 seconds. Same thing happened 2 days before but after doing backwash, it sorted itself out. I can't be really backwash that fixed the issue then.
What could be wrong ?
Busy googling but often forumites give much better help. Thanks.
