leon.davibe
- Feb 3, 2009
@wingnut771
been looking for an affordable/in stock balancer for a buddies 5s configuration
we first tried the cells he got to see if some work and to build a pack with what works ie top balanced and ran without a bms
some cells good now we are looking for a BMS/balancer
the only items i could see for his setup (5S LTO) locally is the, 4s-8s JKbms from lithium-cells.co.za
it does have a minimum requirement of 6cells (for LTO) hence the problem, i do think there is a solution to make the bms run on his 5s setup but budget is a stumbling block at the moment
looking for a cheap solution had me stumble on to this cheap diy balancer , that can work on any S config as individual cells just get resistance added when reaching full SOC, naturally i will have to amend the design to his 2.3v cells ie get a zener diode around 2.5-2.7v still need to research what will work best , and use the parallel design not series
