Did I read the ICASA document right? NO more bandwidth shaping?
The local bandwidth thing wasn't really a plus because we had free local bandwidth up until oct 2005, but the traffic shaping is a step forward no?![]()
I fear what will happen is telkom will abandon unshaped accounts and tell you that what you have currently is unshaped.
explain
k
can i ask something ( I know the answer but still gonna ask - im not soposed to tell but wanna know if ppl know anyway)
does anyone know the contension ratio?
No currently its not in the public domain. In the regulations Telkom is suposed to declare the"contension ratio" quarterly on its web site, but of course Icasa fail to state what they means by contension ratio. Understand there is contension on your local dslam (100 1mpbs adsl lines but only 2mbps from the exchange to edge routers) contension on the ATM network. Contension on local access and contension on international bandwidth. So if telkom state their contension is 50:1 what will it mean?
Personally what would be great to know is the total amount of international bandwidth allocated to ADSL / total adsl connections.
QUOTE]
50 users to 1 line
[edit] but it doesnt mean its 50:1 [/edit]
As I'm sure you'll know Telkom will have to publish key performance indicators including packet loss, average latency and jitter - as well as publishing contention ratios. Hopefully this will indicate if they're intentionally degrading the service.Yes but, there is nothing in those regulations which require Telkom to maintain the "quality" of the unshaped bandwidth. I have noticed over the past few months that on my shaped account i can pull full speed on torrents etc, the difference with unshaped is lower latency and jitter. I fear what will happen is telkom will abandon unshaped accounts and tell you that what you have currently is unshaped.
QUOTE]
50 users to 1 line
again, useless info (not an attack on you, but an attack on Telkom).
50 WHAT users? 384/512/1024? What is a "line" - is is a standard entity? Is the cable "quality", distance etc a factor? Where does the line end? Is it from the DSLAM to a central point? Can the "second" line support the convergence of 10 * 50 user lines?
Smoke and mirrors.
ok the ratio is # : # not on the line. ( sry i misinformed u )
its #:# on a 2meg card in the exchange
and its diff for home and business users ( lower for business )
hope it clears the air
I agree - that doesnt make sense.even though the line/BW costs are the same? Doubtful.
