Portable Solar frames
LandyMan
Centurion
Hi all
So finalising the portable 3KW 5.12KWh system, and the way things are going, might consider panels sooner rather than later.
Based on some other threads, 2 X 545W panels should work well for me. BUT, as is the nature of the solution, I have two questions:
1. Where can I find portable panel stands? (I found these https://tripplehydro-energy.co.za/store/Solar-Ground-Mounting-Frame-2-Panel-Single-Row-p149532304 but are for smaller panels only)
2. What angle are they normally mounted, or is that a variable depending on location and direction?
TIA
Yeah, that is an option if nothing else pops up.
Well I am in the process of DIY'ing my own....
^ Rough sketch.. & still in planning stage. Lucky have access to offcuts that I can work with.
That said its not what I wanted, was looking more for a solution like Renusol roof boxes: https://www.renusol.com/en/solar-panel-mounting/flat-roof/cs/
Might even steal some ideas I saw in:
Thanks man ... DIY definitely an option.
