Possible to build outdoor frame for pull-ups without welding?
jxharding
No door-based pull up bars - this is not the reason for the thread.
My question - is it possible to construct a pull up bar (which will stand outdoors permanently), can hold a 100kg, and without any welding? Cost is a major factor yes.
I'm thinking of this (Key clamps):
http://www.alvinkeyclamps.co.uk/
(I hope one can get these in South Africa)
The idea is to in the end have a shopping list of exact goodies required, then to buy and assemble. Is this possible?
Do you have a drill?
A steel place can cut the steel for you then you can just bolt everything together.
