sonoffafrica.co.za
I get a message from the NAS that tells me it has entered UPS mode and a followup when power is restored.Hey, what are you guys using at home/office to tell if power is on or off? I used to be able to see with my router's IP but now I've got a router backup and looking for a more mature solution.
Ok now link oneA smart plug with energy monitoring. If it goes offline that's a good indication. Better yet several of them going offline simultaneously.
was gonna suggest this oneA smart plug with energy monitoring. If it goes offline that's a good indication. Better yet several of them going offline simultaneously.
I used to do this with an old Android phone, permanently plugged in, and it would send me an SMS if the charger of the phone connected/disconnected.I'm not sure if this qualifies as 'more mature' but you could install Tasker to an Android phone, let it monitor the power state and send an appropriate SMS etc.
If I see my neighbour’s SSID vanish from the local area, I assume that power was lost to our street.
But for scripting on my Mikrotik I use Netwatch to watch an IP of a device that is on municipal power, then I can run appropriate scripts from there based on whether or not it’s pingable
Sigh, I typed out a long reply then the forum timed out and I lost my draft. Version 2:My HAP lite is on router backup power and has Netwatch. Would you care to post your on and off scripts? Also, what device are you monitoring. I'm assuming something with a fixed IP.
?????Ok now link one
Ok now link one
I have similar vizia ones. Problem is they are on the circuit that is fed by inverter. So doesn't really help.I have a couple of these Qualitel / BNETA branded ones. Also a CBI Astute - all part of the Tuya ecosystem. But just about any WiFi or GSM device should work providing it's always on mains.
You might just want to distinguish connection drops from true power outages by delaying notification for a few mins.
