Geoff.D
The 500V is the critical spec change. The extra 5uF will not make much difference to the performance.@fragtion thank you, you are likely correct, I have now ran the system on battery only for 3 consecutive days and it's been perfect, no flicker or strange noises on any of the pumps. Guessing Eskom doesn't really have enough power so we need ripple control?
@Geoff.D changed my capacitor just because it looked old and wasn't an expensive exercise, my original one was marked 400V 25uf, bought a larger one, 500v 30uf, price difference was only R8, works fine, thanks.
