Get a silent running one or you will be disappointed with your acquisition.
Same here. No need for an expensive solution that can't turn the generator on in any case.For now I shut off the main switch then plug the genny into a wall socket. Sorted.
You should put a UPS between the PC and genie if you can afford it.Thanx for the advice all.
Electrician has told me there is a risk running the pc using a generator. Is this the case or would ie be ok ?
