Power Solution for Mini Iron
LDPP
Hi all! I'm on the hunt for a power solution for during loadshedding that could power this type of mini iron. It wouldn't have to power any other goods, and would only have to power the iron for a couple of minutes at a time. Is there anything that could be recommended for this? I know the cardinal rule seems to be to not use any heating products on a battery, but it seems like such a tiny appliance wouldn't destroy everything.
Thank you!
The power rating
200-250w is so low
Does the power source need to be portable and how long will the device be used and how many times per shedding or inbetween recharging
You can use heating devices on battery , it is just a question of are you willing to pay the battery cost to make it happen
Though this device with low watt requirement would run on a 1kw inverter with a 100ah lithium battery on its hottest setting if it was heating all the time through a 4 hr loadshedding
The problem is the entry price
ie the portable units like this one
could power that device for about an hour run time
The portable power units are kinda expensive for how much power they pack
Thank you!
Plenty of solutions for this. What's your budget?
could power that device for a bit more than an hour non stop
The power rating
200-250w is so low
ie the normal entry levwl power trolleys
Wear black, people can't really tell if it's ironed or not.
If you know that you won't use the iron for more than 20minutes , on this specific size battery and have to recharge it before you can use it again
Then
you can use a normal car battery to skimp on cost
Normal car batteries aren't designed to discharge more than 20% of their capacity
If you intend to run it more than that you can swop out the car battery for a deep cycle battery , they are designed to discharge 50% of their capacity so a 100ah would give you 100*12/2=600wh
So you could run the iron for almost 3 hours
If you buy a lithium lifep04
You can use all of the ah rating of the battery
ie a 50ah lithium is equal to 100ah
deep cycle acid battery
In what you can take out of it before causing damage to battery with lead acid
If this is something that you work with and know you are going to doing so in coming years , just go for a lithium battery,
Lead acid batteries are heavy
Lithium is lighter for the same capacity and last way longer so another plus for lithium
This battery below will also give about 3 hrs runtime
you can get a smaller lighter battery if less runtime is needed between charges
but you gotta keep one thing in mind
The iron will pull up to 20Amps so the lithium you buy must have at least 20a constant load battery management system
Another battery lithium lifep04 weigh about 5kg in this capacity
If you can handle heavier you can get more capacity for a better price per ah
The power rating
200-250w is so low
It doesn't need to be portable, but it needs to fit in a little corner ideally. The device likely won't be used for more than 20 mins total per loadshedding session - and then the source can be recharged after the shed.
In terms of budget, I'd rather not splash loads of money on it, but if that's what needs to happen, that's fine. It literally just needs to heat the iron for like 20 minutes in a 2 or 4 hour shed session.
Thanks for all your advice, Leon!
So if you go for one of the pretty units , that tend to be pricey as long as it exceeds the 250w output and has more than 100wh capacity you will be fine
Or if you go for the loose inverter with a battery this size battery would be nice but unfortunately it's max constant load rating is a bit low
You could ask them to build you a battery with a 25a bms
The Car battery will meet that need
The problem with the car batteries and inverters
The inverters won't be able to switch off at the 80% car or 50% deep cycle dependant on battery selected
And requires you to know how much you use and put back to not cause damage to battery
The lithium bms also handles protection against overcharge and over discharge etc
While lead acid requires more oversight
Edit :ie if you use more than initially planned in one loadshedding you could degrade a lead acid
Its a nifty little inverter, used it for camping to keep lights on, phones charged and and while camping.
Use to, as in I sold it to a co worker and in the process of buying a Kool 1Kw Power station for the same purpose. That is if my bloody supplier (Current Automation) can get back to me re availability.
This, for an artist who needs it for her workshop. :)
It seems like all these electricians are ignoring the fact that a plug and play solution would be best for the artist who needs a bit of power to run the iron.
Let's just say the iron needs to run for 30 minutes over a 4 hour load shedding block. If we're assuming 250w for 30 minutes, most plug and play devices will do, but it would help if we knew the exact make of the iron that she's using. Some machines have a surge rating (they use a lot of power for a few seconds when starting up) which means you may need to over spec the solution to cater for this.
@LDPP Do you have any idea what the exact machine she is using is? This would help avoid any issues with putting together a solution that isn't strong enough.
the surge idea tends to be on induction devices, normal resitive loads don't behave this way
sure a pc or a other electronic devices use more at startup ie closer to what their label says
and then tone down to a idle use consumption
it is always a good idea to get a bit more than what you need, in case
what you say makes sense and that is why we get the portable power packs that is a plug and play device
they come at a cost though, not all are willing to pay that premium
edit: not an electrician, so just adding my 2 cents, most inverter devices are designed to cater to spikes double its rated output for very short periods of time ie fractions of a second for startup load and some will even handle a bit of overload for a few minutes above rated capacity , refer to its manual
If using an inductive device
It is recommended to gi for pure sine wave devices
Some inductive devices refuse to start up on modified sine wave cheap devices , or so i have heard from others on this forum
Normally inductive devices will run if the modified sine wave inverter can meet that initial demand
The problem is they tend to run hot on those cheaper inverters shortening the devices lifetime
Inductive loads tend to be fridges pool pumps , induction cookers, fans
Ie normally motors but not exclusively devices that uses coils or transformers could too
