Power splitter connectors, help plz!
dracolusus
Where can I get the 12v molex splitter? I got the Antec 1200 yesterday adn my super old Aopen 1000w doesn't have enough 12v molex connectors. I found something in my cupboard that seems to be a splitter that seems to be working, but only seems to give power to 2 fans. I'm short one point, since I have 6 fans in my case and the other 2 molex are being used to power the 8pin PCIe converter.
Something like this: http://www.easy-touch.com/gfx/resized/800x600/30373-kabel_molex_-_2x_molex_et-9087.jpg . Except that I can plug 2 female molex into it
Thx in advance,
Depends where you are, but when I was in Cape Town I got them from Genex or Rectron - PC stores that buy from them should be able to source you one.
great, thanks.
All the places I asked said they couldn't get hold of it, will try directly from Rectorn if I don't come right.
