The mistake I made when Vumatel came to install my fiber is the have the cpe box installed on the outside wall inside my garage. Convenient for them but a schlep for me when I then wired it via about 20m of Cat6 to Tenda Router above the TV's etc., in the family room.
Especially when I now, with all the loadshedding wanted to power both units from a Riello 600VA ups I have available inside.
Then thought of using a static POE pair to pipe the 12v through to the garage!
Found a poe injector kit for R49 at DC3 electronics but although I measure 12.03v in the garage, the cpe box does not boot when I plug the power into it!
Can't think that the load will let the power drop so much that the cpe does not boot!!!
Any ideas??
Any ideas??
