The 1600W does not tell you anything in terms of the run time, it just tells you how much you can plug onto your UPS, the devil is in the detail of the battery used to power the UPS.Hi all
I need to power a TV power consumption 129Watt.
Mercer true sine wave UPS 1600watt. Using above TV how long will the UPS last after 2hr power outage.
Incorrect calculation.a rough-and-ready calc*ultation:
129 Watts / 230 Volts = 0.56 Ampére
a fully charged 105 Ah battery (assuming it was 100% efficient, and your inverter had a power factor of 1 instead of the usual 0.6 or 0.8) would power the TV for:
105 Ah / 0.56 A = 187 hours
if you never wanted the battery to deplete below 50%, then halve that to 93 hours ~ 4 days
*Assuming it's at 12V.Incorrect calculation.
The 105ah is at 12v so you cannot divide by 0.56.
The real answer
105x12v= 1260wh
1260wh x 50% = 630wh usable.
630wh/129w = 4.9hours
And 100% efficient.*Assuming it's at 12V.
I am afraid it's a lost cause, keep it for your router and other small things and get a proper inverter for your TV.Ok hold your horses.
UPS has 4*12V/9 Ah batteries. Should have stated this from the beginning. Series total 48V / 9Ah.
No 105ah batteries.
Have you paid your tv licence?Hi all
Use this calculator to work out battery size. Your consumption is 129W, divide this by 0.6 power factor = 216.67W.Hi all
Yes every yearHave you paid your tv licence?
