Shard
Yeah, I know. I will first see how it pans out. Might sell the ups, depending on my needs.
Do I need to put a fuse between battery and inverter
That should be built into the inverter, I'd be very surprised if not.
So after just under 2 days of charging, I've caught up to where I was before I ran the unit for 4 hours 20 minutes (79%)
Or get a 2,5kva generator for about R3k.
Makes a little more sense then paying about R2k for battery backup when you can use geni power.
Just a thought?
Would something like this help to speed up the charging time?
http://ecx.images-amazon.com/images/I/810xD6AFtyL._SL1500_.jpg
I bought 1 like this (Auto Gear branded) to charge my bike battery after I had not used it for 3 months.
So just a quick question. If I am buying a UPS with the intention of stripping out the standard battery's and connecting 2 x 105Ah batteries to it instead, is there any advantage of buying the 2000VA UPS over the 1000VA UPS?
Read the spec sheet for both and see for yourself.
Looking at the specs from this site:
http://www.voltronicpower.com/oCart2/index.php?route=product/product&path=37&product_id=52
looks like the only main difference (besides the LED's) is the maximum load they can handle.
I think I'm gonna go with the 1000VA model, as I just wanna power my LCD tv and USB powered drive, as well as 2 x 10w LED bulbs.
I'm glad I bought myself a 2 plate gas stove and 9kg gas bottle.
Yeah that is something to consider as well. The 1000VA is R892 at Takealot and the 2000VA is R1499 so that's a difference of R600.Spec sheet doest say what size current charger is built in . So better find that out before you doing battery mods. But of course its built in with up to 9Ah batteries which take 4-6 hours to charge to 90% , imagine charging a 100Ah to 90% ? how long would that take ? 2-3 days ?
Also Price?
Kind of off-topic here, but I have an RCT2000 (rated as 1200W) powering a Samsung Plasma TV (2011/12 model), and an AVR. The TV is said to draw 300W and the AVR a max of 600W.
One thing I noticed over the weekend, is when the load shedding began, the AVR remained on perfectly but the TV turned off and then on again. This is bad for a plasma TV when this on-off happens (I was told by a plasma-repair shop), so is there anyway short of buying a different UPS to solve this?
-G-
Does the tv do that if the AVR is off when it switches to battery power?
-G-
-G-
If you really serious on buying a quality UPS . PM me and i'll give you a contact.
