PPC and smart phone hype!!
marco
UK
I am disappointed with my expensive HTC WM PPC. Why buy a phone with an OS? OK, it has Exel, Word and Powerpoint, but what for?
You can download some stupid programmes that you never use. And choose to which folder you want to download to.
All you need is a touch screen with Opera Mobile. Much cheaper and just as good.
marco, you clearly have no idea about what it's about. It is about having adevice in your pocket that can be used for almost anything you need done (electronic). It all depends on the user whether the device is good.
Just me cents.
Guess he is referring to Windows. :D Android is way better than Windows IMO. I wonder what HTC he got? They all are supposed to be quite good. And those with Android even better!
+1
I have the HTC TyTN 2.
What can one do with Symbian. Android or WM that makes it worth the money?
And what "advice" do you need from a cellphone with these OS's?
You can't use Internet Explorer as you have to navigate horizontally AND vertically.
A normal phone with touchscreen and Opera is good enough.
Thats not a bad phone, mess around a bit on it, and you can change the view on IE (BTW you get Opera for winmo)
