Pppoe and router connecting! HELP!
armthedark
Heres the situation, im a totall noob when it comes to router stuff, i can only connect to the router (bring menu up), but dont know any settings there...
I have a pc, with a uncapped pppoe connection, and a capped connection.
At the moment all 4 of us in the family connect with my Uncapped pppoe (and i sometimes I switch to capped account to download).
How can i set my router sothat Only I can connect through pppoe and switch connections, and the rest of my family connect through the router (With no PPPOE, on the Uncapped Connection).
(The Reason i need this, is because telkom adsl only has 4 connections at once max!)
If you can help me directly on msn, [email protected], please do!
Or IRC.shadowfire.org <#DC++>
Thanks allot. Remember, any help is help!
Thanks again!
You won't be able to do this from one PC. It will want to connect using one account. (Either through the router setup or through the software setup. In bridge mode it will not use the setup/ username from yout router, but rahter the info from the PC. Problem is that bridge mode is connected to one PC.
Ok, i want to connect more than 4 ppl to the internt at once, but i want to use pppoe, so i can switch accounts and dont have to forward ports...
Sharing a internet connection doesnt work, cos if i connect to different connection then everyone doesnt have internet.
Likewise with Proxy....
Any ideas?
you dont say what type of router / hardware you are using and the type connection : wireless/ADSL/iburst etc?...
Ive got an adsl telkom router ethernet, and a Planet Ethernet router... :p
