Could someone give me a rundown on how I can use Sentech with PPPoE?
Currently, we have two PCs. My PC has the Sentech modem on USB, and I share the Internet connection with ICS to the other PC, which is connected with a crossover network cable. All works pretty well.
I'm going to be getting a 5-port switch, so that I can hook more PCs up if I want. I would like to connect the Sentech modem to that switch - would that work? Essentially, I'd like the modem to be independent of the two PCs, so that I could reboot my PC without the other PC being affected. How do I get the modem to log on? Presumably each PC will use the modem as best they can?
If I have a VPN connection from my PC to work, and I connect it, will it affect the other PC? Currently, using the VPN disconnects the other PC, and routes all my traffic through the VPN (i.e. no more Internet connectivity). I would like to be able to use the VPN without disconnecting the other PC.
What hardware/software would I need. We have XP SP2.
