SHL
- Dec 17, 2012
That's the next test I need to do. So far I've just dropped the switches for any major appliances.Does usage stop when you switch of main isolator to house ?
Not only that, but if you leave it long enough. You'll owe CoT without knowing and through that scheme they nail you interest...Yes. Basically we are now forced to pay to run the municipalities meters over and above what they are smoking us for with the prepaid rates as well.
I know I know ... it is minuscule - but still. Lose-lose for the consumer
How do you unplug the meter? At the box outside?if you switch the mains off just unplug the meter as well.
You can't, it's only the utility that can do that.How do you unplug the meter? At the box outside?
Power is one of those things you don't play with when it comes to the municipal connection. It is normally not maintained and badly installed so chances that you will toast something is really high. Most electricians do have access or can schedule a check. If there is nothing wrong it is a win. If see a magic wire branching out to someone else you got your answer.How do you unplug the meter? At the box outside?
Meter was installed Dec'24. Up until recently, 600 units was enough to get through the month but now, that amount is being used up within 2 weeks.You can't, it's only the utility that can do that.
Is this a new or recent problem? Is the meter recently installed? I can't imagine you could have missing that amount of electricity going off every day.
Okay, you will need to do your homework properly because the utility could make you look like you are imagining things.Meter was installed Dec'24. Up until recently, 600 units was enough to get through the month but now, that amount is being used up within 2 weeks.
If it won't interfere with the comms of the main meter. I have a simple plug in meter that I use to get the consumption for appliances, the UI cannot communicate with the meter if it's plugged in.Also get a secondary power meter installed after prepaid meter , would help alot to proof faulty meter
Did some further testing by dropping main switch and the units stop running so that means the issue is on my side. I do notice that there's one bar permanently on when viewing the meter even though no major appliances are switched on. Can anyone who has the Conlog meter confirm if this is normal?Can’t really consider it a problem until you do.
If it stops with the mains off your meter is just fine and the problem is on your side.
Look up the short codes for the meter and see if there is one to display current which will tell you if electricity is being used.Did some further testing by dropping main switch and the units stop running so that means the issue is on my side. I do notice that there's one bar permanently on when viewing the meter even though no major appliances are switched on. Can anyone who has the Conlog meter confirm if this is normal?
Depending on how it's configured that one bar could even be on for the UI self consumption even when nothing is plugged on.That's probably the signal strength, assuming you are referring to left side of the display.
I was wrong, each segment represents 10% of the max configured load. I assume it just shows one bar if there is any load.
I've installed a Sonoff POWCT because I am sure I am being over billed by COCT. Postpaid with spinning disc meter in the kerbside kiosk.Also get a secondary power meter installed after prepaid meter , would help alot to proof faulty meter
