Running Windows XP Pro, recently re-installed.
It is giving a strange problem the last week or so. At random on startup it will keep saying 'searching for printers' even though they are connected and installed, and this freezes up everything else.
When I try and shut it down, it says PrnStatusMX is running, and I have to 'End Now'. If I then shutdown the PC it takes forever, saying 'Saving Your Settings'.
What can I do? What if I use the laptop when the printers aren't even connected? Is there a way to stop it from 'Searching for Printers' all the time?
Thx!
Thx!
