Problem after installing Catalina
alex2502
After installing Catalina my old Excel is not working .. is there any chance I can install new one for free ?
Furthermore I can't install Amule anymore..... any suggestions?
Excel free in the App Store, 'tho I see it says there are in-app purchases.
Any reason you don't use Numbers?
Also, what's an Amule?
Had a few clients with problems after Catalina, powerpoint, excel... Running the office update seem to fix
their issues.
...I downloaded the new Excel and it works just don't like to pay that much every year.... maybe I should get used to Numbers
Amule is a P2P app like Emule tried to download the latest version but can't even install
If you're okay with Excel, you'll be okay with Numbers. Bonus points, Numbers can export to Excel.
Also, P2P? Like torrents? Go here --> https://transmissionbt.com/download/
Do not pass go, go directly to Transmission.
Transmission won't start downloading.. says port is closed .. even if I put select randomly a port all ports are closed
Maybe give FDM (Free Download Manager) a try, using it for 3 years now, no ads, and can download from Youtube as well.
If you don't like paying for software, why not use Libre Office instead ? I use that across my Mac and PC devices and it's excellent.
