Vie
Just thought I should put this thread in here for the benefit of new users, and give them an easy to use reference.
There are known problems with the Marconi ADSL Modem (Telkom supplied).
* This router is broken (by design)
* It should not be used as a router but as a modem. (as telkom seems to want you to use it)
* If used as a router (the reason you pay for it) it overheats and crashes.
* If used as a router it does not handle LCP(line control protocol) requests well and crashes.
Thanks to ezanolin for summarising this.
Anyway, there doesn't seem to be any real solution to this one. I don't even think a firmware update will help, so we may just have to grin and bear it.
