BandwidthAddict
- Apr 19, 2005
Hello.
Has anyone had a problem playing GuildWars with a Telkom ISP account recently? My NightFall character got stuck trying to connect to "Chantry of Secrets" and my Prophecy character got stuck connecting to "Augury Rock". The problem manifests as an eternal "Connecting" screen. I can sometimes connect to other areas but those are on different game servers.
After some time spent with PlayNC support, the consensus was a network connectivity issue. I have a friend playing on a Telkom ISP connection but in Edenvale (JHB) (I'm in the vacinity of Randburg (JHB)) and he has no problem. I switched to an IS account; apart from the increased latency, the game works with no problem.
The GW problem started on Tuesday, around the same time I started having problems with the LCP connection; the LCP would drop around 21:50 for 15 minutes leaving me with no internet connectivity. My friend did not experience LCP issues so I think there is a causal relationship between the two.
Has anyone experienced such a problem, or do you know what might cause it? I got the IS account to test the connection so it's a wimpy 1GB account but I would really like to get Telkom to fix the problem so any advice would help.
Thanks.
Thanks.
