Problem seeing java based ip cctv
john1
Hi I'm hoping somebody can help me. I use iburst to view some cctv feeds over the net, normally you just go to the no-ip address and it loads (java based). For the last two months it has stopped working, I have reinstalled and set up the web server but no luck (this connects via uncapped adsl). Recently i got adsl and guess what its working!! same laptop just connecting to the net via adsl.
Any ideas how to fix this because I cant change all the sites to adsl
I suspect the same is there any way you can request them to open required prots?
Not so sure but to test the port just do a telnet: telnet $_IP_$ $_PORT_$
If you cannot connect with iBubbles but on your DSL line, then you should call them and find out. A kinda remember there being a port issue when I was still on iBubbles 3yrs ago but I was only on iBubbles for a few weeks so I ignored the issue.
PM me the camera IP and access and I'll have a look.
