problem with adsl2+ tester rui yan 2100
slamica
Hi,
Im having a problem with rui yan 2100 adsl2+ tester. It wont measure line parameters. The link light just slowly blikns and i assume it doesnt even recognize the connected cable.
Anyone has an idea what to do?
i tried to find some software to install it again, but no success.
Thanks.
Are you 100% sure your exchange supports ADSL2+? If it doesnt it wont sync at all.
exchange?
Rui yan is set to measure adsl2+ line in options. and dsl line is adsl2+
so i think this part should be ok.
exchange?
You get exchanges that support
ADSL
ADSL2
ADSL2+
Try set it to ADSL or ADSL2
