Re:1
I did some experiment today and still don´t work....
I want to create network bridge,but it won´t to create cause it wants two connections as you said...and I have two connections!?
1st: external DSL modem connected to PC through USB
2st: network adapter (on board)
so why i can´t create bridge (when I selected two connections option Create Network Bridge isn´t aviable)
current settings:
SERVER:
LAN:
IP - 192.168.0.1 (set when I enabled ICS)
Subnet mask: 255.255.255.0
Workgroup:OFFICE (set throught Netwok Connection Wizard)
Internet:
Internet connection sharing Enabled(ICS)
IP: obtain automat. (given from ISP)
DNS: obtain automat. (given from ISP)
(also set server as computer through which other computers connecting to internet)
CLIENTS:
DHCP - enabled
IP - obtain automat. (also tried 192.168.0.2 - 6)
Gateaway: - (also tried 192.168.0.1)
DNS -obtain automat.
Workgroup:Office
(also set client as computer which are connecting to internet through other computer)
but there is a little problem:
- when I enable ICS on server and set all IP´s to obtain automat. or define static IPs -> I can´t see all computers together in Office workgroup!!
- just in one case I saw just one client and also server.I checked connection with ipconfig /all on this pc and everything was OK
DHCP enabled - YES
IP: 192.168.0.51
Gateaway: 192.168.0.1
DNS server: 192.168.0.1
I mean that ICS and DHCP server was successfull...
after that in internet Options set new connection as Broadband connection (DSL,LAN)
run Internet Explorer and nothing bonk
after restart it was all gone!!!....
I don´t know how,but IP was set to 164.194..... and subnet mask to 255.255.0.0....DHCP server disabled....after restart all clients PCs I saw all computers in Office workgroup think ,but they all have IP 164.194...
I did everything again,but I still getting IP 164.194...
I don´t know whats next?
Doesn´t have switch static IP?
(1st port etc.10.0.0.1 ,2nd port 10.0.0.2 and so on)
It´s different between IP 192.168.1.1 and 192.168.0.1?
Any help would be much apprecieted.THX
