Problem with dual view. Please help
Azbubu
Kapkaupunki
Hi. I'm suddenly having a problem with my SD PVR 1. TV1 only has channels 131-134 and 319 whilst TV2 has all the channels.
In the TV1 tv guide I can record any of the channels and play it back.
Any idea why?
This is how it's connected. There are only 2 lnb's, my previous place had 3 lnb's. But I had the same problem at my previous place earlier today.
Any idea why?
try swaping the LNB cables in the decoder, if the problem is reverse (ie what worked on tv1 now only works on tv2) then either you lnb is stuffed or the partiular cable could be the problem, but if the problem is still exactly the same your decoder could be messed up.
