I battling to get a connection to my modem with the ethernet cable. The cable worked fine when I first tried it, but I usually use USB so I can check signal status. I had difficulty getting a link to the modem last week with the ethernet cable, then eventually succeeded after much plugging and unplugging of cables (modem connected directly to Mecer wireless hub/router - normal port which I assume does auto crossover).
I have now spent a couple of hors at work trying to connect the modem first to our network using a crossover cable with F-F adapter, then to my laptop with no joy.
I have noted the following when trying to connect the modem directly to the laptop (no crossover cable as I assume the ethernet cable is a crossover)
If I leave the Link speed & Duplex of the NIC to auto I have no link and the green light on the cable is off.
If I set it to 10Mbps full or hal duplex i get the same as above.
If I set to 100Mbps full or half duplex, the green light on the cable comes on, but the laptop still shows cable disconnected.
Has anybody had a problem liket this before or know whether the cable or modem is faulty? I've tried all the usual things like power modem off, have confirmed that my laptop NIC and crossover cables work correctly. I've also opened the connector that plugs into the modem to confirm that none of the solder joins have broken off. What should the connection be set as if not auto 10/100 full or half duplex?
Have tried contacting SlowComm but am still waiting for them to come back to me.
