Problem with http on Telkom Mega 200 VWR
jsalie
Hi,
I've had no luck getting my webserver to work behind the Telkom router. All my other services, mail, ftp, etc works fine using the Virtual server setting. I've tried changing the admin web server port to 1080, however when I telnet to port 80 on my wan ip from the internet, it still seems to connect to some service. I suspect the NAT configuration is reserving port 80, but I cannot disable this. I tried doing this from the telnet interface on router, still no luck. If I nat 8080 on the outside to 80 on my webserver, this works. I want my webserver to be accessible on the standard port 80 though.
Any assistance is greatly appreciated.
Thanx.
problem solved :) it seems most ISPs are blocking port 80 and 25 for 'your own protection'. MWEB does allow you to disable this function, not sure about Telkom.
