Problem with Javascript in Firefox
pedruid
Port Elizabeth
I am a new user to Firefox and I have enabled Java and Javascript in the tools/options.
I can view the script but am unable to print or email the contents.
I need to get this to work as I need to print some overseas flight details. Can someone please HELP:confused:
When something is disabled, or could be enabled you a panel will display for a few seconds once you open the site, to allow you to enable all the features on the website. Usually the panel will be at the top of the page from where it starts to be rendered.
Sure your printer ect works? More information, like if you are using XP or Linux, would help.
Thanks for your response EDC.
Yes my printer was on and i'm using XP Home.
Come on guys there must be more advice out there which will be much appreciated.
Still:confused:
Use IE7 then. Would determine if the problem is specific to Firefox.
Or just print screen, paste it into an imaging program, and magnify the flight details portion before printing?
