problem with Rasppoe
Enigma77
I try to install Rasppoe, and when I get to the protocol and try to install the driver after unzipping the file, it gives me a 0x800700C1 error. any ideas...
How are you trying to install the "driver" ? Remember, you need to be in the "Properties" of your Local Area Connection and click "Install" and then "Protocol" and then direct it ti where RASPPPoE is extracted.
If you doing that already then I do not know :)
Maybe try the readme file, it should have come in the RASPPPoE archive, they are htm files eg README2K.HTM :)
